Not only am I brain dead but I am lazy too.
  • Not only am I brain dead but I am lazy too.
    The deal is I can not remember how many gallons one of those 35 lb. cubes holds and right now I am too tired to go out there and measure.
    Any body know for sure?
    Want to see How far I can really get on what I have. Tanya
    Vegetable oil weighs about 8 pounds per gallon, so 4.375 gallons are in a 35 pound cubie.
      Yep, that's what I use to figure how many gallons I have.
      So far it's been right on the mark.
        Thank you both very much. Off to figure out how much is there. Tanya
          No problem! If you're lucky, you'll have more than you originally thought! Haha..
            i thought a cubie was more like 4.7 gallons...don't remember why i thought that, just did...
              I just guesstimated at 4.5 myself. Surprised they don't print that on the label along with the weight. Hmmm....
                Believe it or not I actually measured it out once at 4 gallons and 3 quarts. so 4 cubies would be roughly 19gallons.
                  Looks like Clay's estimate of 4.7gal/cube was pretty close then.
                  That'd put 4 of them right at 18.8 gallons.
                    yeah, seems like the weight of the oil was less that 8 lbs - gal. and it came out to 4.7 gall for 35 lbs.
                    But whos measuring anyway...oh, jason is...LOL
                      According to Wiki vegetable oil is 4.7 lbs per gallon.
                      2002 F250 7.3
                      If it walks like a duck.....
                        Well I decided to figure on 4 gallons per cube then I will have more than I thought and will be able to go farther than I count on. Besides all that weight in the bed of the truck is probably going to make my mileage go down.
                        Tanya
                          Now Tanya, what does that really matter. Its Free, well mostly.
                          Where are you heading this time?
                            um..you sure about that? That would mean a 35 lb cubie is 7.44 gallons.
                              Whoops, I meant to say 4.6 - 4.7 gallons per cubie.
                              Wiki - How much does vegetable oil weigh?
                              Here's a container site showing a cubie at 4.6 gallons.
                              http://www.containerspecialtiesinc.com/35Lbs.htm
                              Should be 7.61 lbs per gallon.
                              2002 F250 7.3
