Accessory Delay shutoff Issue Fix!!
  • Accessory Delay shutoff Issue Fix!!
    Some of you will be Ecstatic to know that we have finally isolated and fixed the Radio Delay issue that the 2002-2007 trucks have. No longer will you need to wait until the truck is shut off to open your door. The door accessory delay shutoff will work normally with a simple wire change. Look here http://www.dinofuelalternatives.com/manuals.php and open the one titled "Engine Run Relocate for 2002-2007"
    :cheers:
    Jason - Any similar fix available for the 99-02 years to keep gauges operating and engine able to rev during auto shut-down? Thanks. - Patrick
      THanks Jason!
        I have kinda gotten use to it the way it is but may have to look into this.
        Thanks for the update!
          Yes there is. Just move your engine run wire to the other side of the PCM diode int he fuse box. THat means instead of using the WH/LB wire, use the R/LG wire. ALthough once you do this your OEM keyless door lock will not work until after the truck shuts off.
            Thanks Jason. Really appreciate that info. - Patrick
              I made this change on my 06 and I now occasionally get a CEL. It's been going on for about 3 weeks now and I can't figure out what the secret shutdown sequence is to trigger the CEL but it only happens on about 1 out of 4 shut downs. The code is U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module. Anyone have any suggestions?
              By the way, the radio now shuts down properly just like it did from the factory.
              Thanks,
              Eric
              2008 F350 CC SB Lariat Spartan tuned
